Hi folk, I’ve recently become the owner of a 2006 r52 that has a couple of frustrating issues. Firstly the car will only start and run on the second turn of the key... on the first attempt the car will crank and fire up but will cut out almost straight away and then fire and run on the second attempt. This is the same if the car is hot, cold, has sat a day or two or just been running. The car runs fine, the fuel pump make all the right noises and I’ve tried both keys???? Any ideas?? The other issue Is that the clock and the trip meter keep resetting, I’ve set the clock and taken the car for a run, I can turn the ignition off, leave the car for a bit then turn ignition back on and the clock still works and the mileage is retained on the meter but as soon as the engine is cranked both disappear and the clock needs resetting. Battery seems fine along with connections??? Please help if you have any ideas.
