1 - 10 of 10 Posts
Hi guys,
I have noticed the last maybe 30 miles my stop start is not working, i have messed with the button and looking through the setting but can t get it to stop when in neautral??? Any ideas?
I had my battery disconeected today and it seems to be after than although not sure if this is anything to do with it or not ???
MINI One Seven
If you've got the air con on it doesnt turn off as much, or you've not done a long run, or the engine is cold, the car won't turn off :D
Or the battery voltage could be too low. If the juice from the battery drops too much then it won't stop/start incase it can't actually start again
Mini Design Philosopher
The start/stop function will deactivate under many conditions including:
having the air con on;
having the heating on;
the engine not being warm enough;
the outside temperature being too cold; and
not enough charge in the battery
I noticed this on the 120D I had for the last couple of days, the Stop/Start hardly come on at all. I just assumed it was because the weather had got colder recently.
1 - 10 of 10 Posts
