1 - 10 of 10 Posts
Could anyone tell me what the strange little sensor on top of the dashboard does. My dealer doesnt know what it is and neither do the service dept. It is built into the small cap that sits right in the middle of the dash just under the windscreen. It looks like an LED from a distance but when you get up close it is not, its more like a sensor of some sort. I have the alarm so maybe its to do with that.
Please can anyone shed any light on this?????????
Thanks.
By the way this car is fantastic, only picked it up yesterday and im in love.( It does slightly pull to the left but i will wait for a fix.)
Red/White,Red Int,Chilli pack,Climate Control,Alarm,ASC, Cd Player and TLC.
Yes, it is part of the climate control system. What it does I am not sure.
Moderator & Sponsor
I'm guessing it is the temp sensor to tell the climate control whether to heat up or cool down based upon what temp you've told the system's thermostat you'd like it to be all the time.
My wife's Nissan with climate control has it's sensor mounted on the dashboard just like that -- I would have thought sitting where it could be in direct sunlight would give bad readings, but that is apparently the way these things are done. :)
In the manual under the climate control section it says that the sensor is built into the climite control unit itself (bottom righthand corner). Because of this i wasn't sure what the one on the dash was for.
Thanks.
It is linked to the Climate control and is placed there
to take into account the heat from the sun (apparently we see that in summer);) and I would imagine this then helps
control the Aircon.
Something like that anyway:D
Graham,
That is correct I have the same set up on my VW Passat. It does sense the intensity of the sun and then adjusts the aircon to suit.
On a hot sunny summer day (stop laughing), try covering the sensor with a dark cloth. The aircon should adjust for the 'sun' disappearing.
1 - 10 of 10 Posts
