2005 MINI Cooper S
I'm trying to replace the front axles (torn inner boots), and I'm having trouble with the left side axle nut (I got the right side loose). I bent the tab on the nut back out, but wasn't able to get the nut to turn, even with a breaker bar & extension. I thought maybe I hadn't gotten the bent lock completely out, and ended up using a dremel tool to grind that bit of the nut off. I STILL can't get the axle nut to turn, even after soaking it with break-free and putting an impact wrench on it! Any suggestions?
I'd hate to have to grind the nut off; that's a lot of metal to remove. I do have all-new axles, though, so preserving the nut and/or axle shaft is not critical.
Thanks for any help!
David
David
