Hello
I have recently purchased a 2006 Mini Cooper. It is naturally aspirated but I was curious, can I bolt on the super charger from the Cooper S model? I have the entire super charger assembly available too me from a doner car.
you haven't got the different valves, pistons, rods, crankshaft, and piston oilers the charged cars use
If I had the valves, pistons, rods, crankshaft, and piston oilers would it run correctly?
If you have the correct engine you need the wiring and ECU to run it, plus ideally the gear box.
its not an easy conversion nor would it make sense over buying an R53 and selling your car.
