I have a Mini Countryman 2012 1.6 petrol engine, and the problem I have is this. When accelerating it pulls fine up to around 3800 revs(ish) it will start surging. It has had a new chain (checked timing), solenoids etc. Also a new clutch which the local garage diagnosed, but still the same. No fault codes stored.
throttle body maybe or pcv valve perhaps might even be fuel pump in the tank maybe,, or fuel tank vent valve on bottom of the inlet manifold ,, could even be vanos sprocket live data run should work all that out,
I would check the spark plugs and coil packs, Then I would replace the Vanos Solenoids. As you have the N16 engine.
buying one coil pack at a time. Using that brand new one and going along the engine swapping that good one out for another listening for it to even as you drive it each time.
Sometimes the brand of spark plug you run and turn to garbage under higher RPM. Not a problem with one spark plug more like all of them. If the car is not running tip top for the most part.
surging more likely to be a timing chain issue or and vanos sprocket,, need live data run on it see what it doing and when etc, if had spark plug of coil issues it would have misfire counts on live data also surging and misfire feel differently
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
MINI Cooper Forum
