I bought a 2009 Mini One Graphite 3 weeks ago. The guy I bought it from must have had the whole engine power washed of oil, because when we drove it all was fine (No smells)
FastForward 2 weeks and I start to smell oil coming in through the heating blowers when I am parked at lights and junctions. When I have a look under the bonnet, :oops::oops: Sooooo much oil.... It looks like its leaking from the Head gasket (i think?) or is it a valve cover? It is so bad it makes me feel ill.
Aside from the smell I have now noticed it is starting to drip onto my Tarmac driveway :-(
Apart from the obvious plastic black cover leaking. is there other places I should look at or that are popular failure points on the 1.4 non-turbo engines. The guy who sold it obviously knew what he was doing as it would take a few weeks for this issue to raise its ugly head. I am asking as there is so much oil it is hard to pinpoint the exact location of the leak or leaks
sounds like the pcv valve in rover cover is leaking
or the plastic pipe that goes to it
Today after I washed the car, I took a look under the bonnet around the Valve cover and this is what I was greeted with.
I can't find the image I took from below the car, but it is absolutely covered in oil. I also removed the Plug cover and inside the 2 deep holes which houses 2 x of the screews that seem to hold the rocker cover on have a pool of oil inside them.
275953
275954
275955
275956
275957
