1 - 1 of 1 Posts
Having some real problems with my 2007 R56 Mini Cooper S.
Short version is the car is having problems in normal driving conditions with the throttle. When you are accelerating the throttle just cuts out, essentially the throttle pedal stops doing anything even if you put it to the floor. Engine doesn't cutout or spluttler. If you release the throttle pedal and accelerate again it might be fine for another 20 seconds and then cut again doing anything again. It has been sporadic and non-consistent as we had a whole day driving it last week without the issue, but now it is here again. DSC light comes on and the brake lights have started being stuck on as soon as you turn the ignition on.
So far it has had a new brake pedal sensor/switch and a new battery which hasn't helped. We thought the brake pedal switch was faulty and telling the car we had the brakes on so it was cutting the throttle... but not helped.
It has had upgraded Brembo front brakes and new calipers all around although the issues didn't start straight after that, maybe 1-2 months later.
Really stuck on this, anyone have any ideas please?
Fault code list:
Car Scanner ELM OBD2
DTC report
Selected brand: Mini
VIN: WMWMF72030TT36128
============1==============
2FAA
Raw code: 2FAA
ECU: Engine control unit
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
============2==============
2FAA
Raw code: 2FAA
ECU: Engine control unit #1
============3==============
C914
Raw code: C914
ECU: IPDM/Junction box (JBBF)
Status: Test conditions are met, Validated and stored in non volatile memory
============4==============
5E56
Raw code: 5E56
ECU: DSC/Traction control
============5==============
5DF3
Raw code: 5DF3
Status: Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle
============6==============
5E50
Raw code: 5E50
Status: Pending fault present, Validated and stored in non volatile memory, Validated fault present at time of request
============7==============
9E2C
Raw code: 9E2C
ECU: Steering column
Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
============8==============
9E2E
Raw code: 9E2E
============9==============
5E56
Raw code: 5E56
ECU: ABS/DSC
============10==============
5DF3
Raw code: 5DF3
ECU: ABS/DSC
============11==============
5E50
Raw code: 5E50
ECU: ABS/DSC
============12==============
E738
Raw code: E738
ECU: Climate/heater/Air conditioning
1 - 1 of 1 Posts
