1 - 9 of 9 Posts
Would Mini dealer allow you to put a car in for a service early?
I have just acquired 10 month old 8,000 mile Mini Cooper which has service indicator indicating service in 1800 miles. I do low mileage and would prefer comfort of servicing now.
Brycem
M2 Bapmaster
Woa, that's probably the highest service value i've heard of, I thought most people ended up getting there's done at 8500. Anyway to answer your questio, I think nope they don't allow it that far in advance, normally just a few hunred miles either side. But i'd double check with your dealer to be sure. :)
Brycem
Depends on what you call low mileage, if you clock up 1800miles in the next 3 months id take it in then, as long as all fluid levels appear to be ok, if you bought the car from Mini they should have given it a good once over before selling it, but dont think they will usually service your car until its less than 1000miles before the service so you probably wouldnt have that long to wait anyway.
Brycem
I would just wait until the 1800 miles/2 years are up. The first service isn't until approx 25k miles anyway. The 10k first one is just an oil change.
Dunno, I thought I pushed mine pretty hard, but it says it'll need doing about 11k miles. (MCS)
In exile, down SOUTH!
I think I had mine at around 9k miles, and believe that you should start planning to service the car with a few hundred miles to go :)
A few hundred miles either way is fine apparently, as mentioned by Skinny :)
DK ;) :apple:
1 - 9 of 9 Posts
