The original hose gets brittle and crack over time. Easier just to replace with silicone hose and T bolt clamp.
thanks for the reply!!The original hose gets brittle and crack over time. Easier just to replace with silicone hose and T bolt clamp.
fantastic!! - thanks for the link!Yes, I use the Samco one and that is the same. The aftermarket silicone hoses moves the sensor further up.
This should help
How to install a forge inlet tube on a 2010 JCW - North American Motoring
Drivetrain (Cooper S) - How to install a forge inlet tube on a 2010 JCW - If this thread doesn't make sense, it is because I have re-purposed it to be a detailed write up. Here it goes: Forge offers a silicone alternative to our cheap rubber/plastic inlet tube that have been know to break (some...www.northamericanmotoring.com
I was just being lazy!!.. i've got a caliper so I'll nip out tomorrow and measure them.. (I'll post back here for reference!Not off the top off my head, but if you have time measure the diameter and buy within the range as and tighten to required size ie 45mm - 60mm if diameter is 50mm.
Might even be some measurements if the google.
