Licence Plate bracket
It is a piece of cake. To remove mine I removed the screws as you have done and then there were two peices of double sided tape holding the bracket up. Rock the bracket back and forth while pulling with constant pressure and it should give way easily. Use GooGone to get the sticky stuff off. Good luck. It looks great with the bracket off.
I posted the same thread about a month ago with picks of the car if you want to try and find it.
