Water coolant crossover pipe
2896 Views 1 Reply 2 Participants Last post by  JTownPBX
Cooper S R56 N14 - just spent the last 3 days replacing the water pump & crossover pipe, the job is an absolute PIA ! Much thanks to the Y tube “how too‘s“
especially “project mini,” for anybody else tackling this I found thesee videos the were most helpfull. Despite removal & fitting of the water pump, I found the crossover pipe was a right mare. Something I found not in any videos was “tips” in fitting the cross over pipe into the rear of the water pipe. After 3 attempts at this (1 & 2) both resulted in a leak from a poorly seated O Ring, I ended up using a 34mm o ring (the o ring that came with the oem part got trashed), by dunking the end of the pipe with the o ring attached into HOT water for 2mins then as quick as poss to the car & push it straight into the rear of the water pump....goes in easy, I guess the o ring is cold and solid, by heating....it becomes more pliable?
I really did get pi****d off with fitting the pipe & nearly gave up so hopefully this tip might help another diy owner who is struggling with the cross over pipe. TS
Thanks for the input. on that. any way that gets the job done is a good way. I like to use
And apply that to the O ring on between the hard pipe and the thermostat housing. As it is water proof and good to 400F degrees.
