Hi can any one give me imfo on how i might be getting a small amount of water in my boot i have cheaked the rear lenses seem dry. !!!! Thanks.
Try the third brake light. The seal gets dislodged and water gets in.
Make sure the weather seal is properly fixed around the hatch opening as well.
Ok thanks i did look at that it didnt look quit wright i will take it out and deal with rudder ex.thanks
Hi I had this to, soggy mat in the boot, I put a small piece of sponge under the rubber, seemed to solve the it..
Let me know if you want a pic
Just bought a brilliant condition R53 and found it was slightly damp under the rear carpet - but no rust, put new seals on the rear lights, changed the high level brake light and then noticed the rear quarter chrome/rubber moulding on the rear near side window(not the rear screen) had come away slightly from the glass. Having researched the clips arrangement I just gently pushed it back in until it stopped clicking and all seems good. Just in case it helps anyone else as I hadn't found this cause in my extensive browsing of boot leak issues!
