has anyone had difficulty putting A new link pipe from the water pump to the thermostat? I can’t get the pipe into the water pump enough that the thermostat lines up. All parts are right.
2006 R56 1.6.
Thanks in advance
I'm in the middle of doing this very thing. Can't get it in for love nor money. Just came back inside for a break before I smash something gratuitously!
Finally sorted it. The new pipe I bought would not go in at all as I couldn't get it square enough that the o ring wasn't getting squashed out when trying to shove it in and I was having to adopt a twisting motion as it's a massively tight fit.
Solution was removing the bracket around which the pipe is cranked (easy as I have all the inlet side off) so I could hit the water pump dead square and NO GREASE as this was causing the o ring to squish too.
Nearly 3 hours. Ha ha ha. No way could I ever hope to earn money doing this!
Now to have a fight with the new thermostat housing...
