.......could be imagining this, since it's almost imperceptible, but I thought I experienced it a lot today. Only seems to happen in 5th gear at around 3000 RPM as you hold it steady on the throttle (or at least that was were I noticed it most).
Seems almost like a hesitation (not really a misfire or loss of power; it's weird) but the pick-up is immediate if you step on the gas. By the way, the MCS only has about 350 miles on it. I did fill her up with Exxon-Mobil premium gas......maybe I got a bad tankful or maybe the ECU is simply adjusting itself ? Apart from this, it starts OK everytime and otherwise seems to run pretty smoothly. Any ideas ?
