Only Unbalanced
I'm trading up from my 05 Cab to a new Clubman and I'd like to bring my current set of wheels. The MA tells me the pitch or threading or spacing or something is different between 05 and 08. Gospel, or a snow job?
Thanks!
Canned
What wheels are on your Convertilbe?
Two production changes need to be considered:
  1. On July 12, 2006 the size of wheel bolts changed from M12x1.5 to M14x1.25. While all OEM wheels have holes large enough for either size wheel bolt, some aftermarket wheels cannot accommodate the larger size.
  2. In August 2007 the Tire Pressure Monitor System for the US market switched from indirect monitoring (using data from the ABS sensors) to direct monitoring (using data from sensors inside the wheels at the base of the valve stem).
    Not all aftermarket wheels can accommodate the sensors required for the direct tire pressure monitoring.
