07 JCW
I have a problem with my runflat light and my ABS light coming on amber in my MCS, looking through the forums it seems this is a problem with the wheel speed sensor..
So my question if you can help is....how many are there (is there one per wheel?) and what do they look like??
I am thinking as this is intermitant it could just need a clean and a carefull squirt with some WD.
Yes there is one per wheel. The front is in the top of the hub carrier and the rear is in the back of the trailing arm. Easiest way to find them though is to remove the wheel and trace the wiring. As far as I am aware you will only see two wires, the pad wear sensor and the ABS pulse generator. The pad wear sensor is only on the front left and rear right.
