Which Spark Plugs for Mini One R56 - 95Bhp
955 Views 1 Reply 2 Participants Last post by  kamilmarshal96
I just bought some NGK spark plugs for my mini one -
NGK SPARK PLUG - PLZKBR7B8G Spark Plug - PLZKBR7B8G (gsfcarparts.com)
i noticed on the engine code, for the part on GSF, it says N12B14, but when i checked the engine code against another source, it says the engine code for my mini is N12B14AB
my question is.... should i be looking for a spark plug for the N12B14AB engine, or, should these NGK ones be fine?
the main reason is i didn't want a degradation in performance as it struggles at the best of times.
It's important to ensure that you use the correct spark plugs for your vehicle's engine to maintain optimal performance. While the NGK SPARK PLUG - PLZKBR7B8G you purchased is designed for the N12B14 engine, there seems to be a discrepancy with the engine code you found from another source, which specifies N12B14AB.
To ensure accuracy, it's recommended to consult the official documentation or reach out to your vehicle manufacturer or authorized dealer to confirm the correct spark plug specifications for your Mini One with the N12B14AB engine. They will have the most accurate information regarding the compatible spark plugs for your specific engine variant.
Using the incorrect spark plugs could potentially lead to performance issues, so it's best to double-check with the manufacturer or a trusted source before proceeding.
