Hi there, been viewing the forums for some time now, havnt really had much luck with my particular question.
I have a Y reg ONE, indi blue, was a promo car apparently.
Anyway, im after fitting some genuine xenon headlamps from the same years, up to 03 i think it is?
My question is, will the exhisting lighting wiring loom on my car fit the xenon headlamp connector when it comes to fitting them? Im not too fussed about the headlight washers as i will just block those up, dont really have any use for them....
Thanks Chris
Banned
Its not just a straight swap from standard lights, as you need the auto leveling fitting too;)
Oh and the washers are required I believe for passing an MOT
so what is the auto levelling kit? Why wouldnt the stuff from my others lights work?
As for the mot, would just fit the other headlights for it....ruling out the need for the washers
Banned
Suggest you try the search feature, as you are not the first to think this can be done easily, so you can read how others have given up on the idea;)
