I have a 2013 r55 Clubman. The windows don't seal as tight as they should at top and sides. I've seen on some models when you remove the door panels there are 2 screws that will adjust the Rake and will put more pressure on the top seal. I don't see those on mine. Are they located somewhere else on mine? Thanks
This is the best service manual if you work on your Mini. It looks expensive until you get a quote from a shop!
