Try disconnecting the battery overnight; that will let all the computer memories drain down.
While it is off, clean all the battery terminals & earth connections - Clean, Bright & Tight.
Close the doors & make sure everything is turned off, including any added accessories.
When you reconnect the battery, do it once, firmly - no sparks - & tighten the terminals before you do anything else.
