Dooper Scooper
Guys,
Anyone had to change the nozzles on their R56? One of them is all blocked up, and no amount of needle pushing is clearing it :(
Gonna try and get a compressed air can at lunch but failing that, I'll need to replace the nozzle end.
Anyone got any idea of the unit cost??
MMC Member
I had an issue with a nozzle on my wifes car. I'm sure if the MINI has these, but there are little ball valves that keep the fluid from backing out of the line. On her car on of them had actually jammed shut. I replaced it and all is well.
Might be worth looking. I found it by disconnecting the line and blowing through it to see if air would pass. When It did, I saw the little valve and checked it.
