1 - 11 of 11 Posts
hi there i just got my self a cooper and wow what a car, i got this cooper wiht normal driving lights just wondering has wnyone fitted in the new xenon headlights in a cooper before? is it possible??
luckyMCS
welcome to mini2 mate... :)
It is possible.Not heard anyone did .I'm planning to install new xenon headlights to my 2004 MCS,retrofit kit number for 2005 xenon headlight is 63.12.0.309.427 cost EUR 1200+VAT(inTurkey,it can differ) without ins.charges.
nice motoring......
nice motoring......
What comes with the kit?
luckblackbird said:
Only for the cars built before09/03 ZKE(electronic body module)must be replaced(TIS 6135510) check this out:
http://www.motoringfile.com/files/2005_headlights.pdf
other than this it contains all necessary equipment,wiring,lamp,frame etc.
The link you gave me has 4 different retrofit part #? Mine was build 04/03.
63 12 0 309 425
63 12 0 309 426
63 12 0 309 427
63 12 0 309 428
luckyMCS
63 12 0 309 425
63 12 0 309 426
63 12 0 309 427
63 12 0 309 428
I checked the part numbers from my dealer before I posted :)
first one is 2005 non xenons.(63.12.0.309.425)
63.12.0.309.427 is correct part number for 2005 xenon retrofit kit for the cars that built btw 09/03 and 07/04.(Probably it is right also for you,but need new ZKE)
Second and fourth ones were not recognized by my dealers system.
as mentioned you've to replace your ZKE,but I don't know its part number or price.
ugur
mini.sg
Hi,
Does this kit include the head light washers? Are the 05 washers the same part number as 04 washers? Cheers.
luckyMCS
mju said:
Hi,
Hi,
No,kit doesn't include the washers! you've to purchase them separately,extra EUR 319+Vat(here) :eek: probably same part number for both 04 and 05
cheers...
Ugur
thebigyin said:
Try the kits at this place
http://www.hidexpress.com/
399 dollars for all the gear you need for two lights.
I do not believe that this kit is legal in the USA, Canada or UK as it does not contain self-leveling mechanism or washers. These are required by the governmental agencies. Make sure that you check with someone knowledgable before you purchase anything.
1 - 11 of 11 Posts
