I think it may be a clutch problem but need advice plz.:confused:...
Wife's 04 mini suddenly won't engage gears!
It went all of a sudden, no warning noises,smell, slip or anything, I can depress the pedal and can put it into gear, but when you release the pedal... nothing!!! :mad:
No leaks showing, only 36k done but looking at threads that is not uncommon for clutch to go on these things!!! :angry:
Looked, but can't find same symptoms listed so hence this thread
Advice required please. Car is stranded on drive and need to know where to tow it
Thanx
1 are you sure its in gear? and not a selection problem ie cable
2 are you sure its not a driveshaft problem -
No I'm not 100% -any guidance on checking these? How, Where, Can I see the cables? ( I read they were problematic on 02's but not sure if still applicable?)
It certainly feels if its going in... i.e I cant put it in gear until I depress the clutch but then no 'bite' when released
