2005 s throwing codes - MINI Cooper Forum
First Generation CVT & Automatic First Generation MINI Automatics from 2001 - 2006
post #1 of 4 (permalink) Old May 26th, 2018, 04:49 AM Thread Starter
Local Time: 11:07 PM
Quoted: 2 Post(s)
My 2005 mini Cooper s is throwing codes and I'm not sure why. I was thinking the and module needs reflashed but I'm not sure.it went into limp mode I think the other day and then went back to normal but still has these codes if anyone could help I would appreciate it.
Bernhardt97 is offline
post #2 of 4 (permalink) Old May 26th, 2018, 10:48 AM
Quoted: 63 Post(s)
United Kingdom Male View ExclusiveWorkshops's Classified Ads
Garage
I'd have thought anything saying system voltage is that low needs the battery charging and testing with the terminals cleaned and checked for tightness, as well as any obvious earth points and test again, it may play havoc with these cars full of modules, so only my2p
ExclusiveWorkshops is offline
post #3 of 4 (permalink) Old May 26th, 2018, 02:46 PM Thread Starter
Quoted: 2 Post(s)
I checked the battery with a checker and it came out good it's also spotless of corrosion and it's tight someone told me it through that code because when I was working on my car for a few weeks the battery died. But the code won't clear
post #4 of 4 (permalink) Old May 27th, 2018, 04:08 AM Thread Starter
Quoted: 2 Post(s)
Ok so I cleared codes with inpa and now there is only the 5e15 code now also found something else I tested the fuses and the f5 fuse(Control Module For Instrument Cluster/Diode) didn't light up with my tester so I took it out and it wasn't actually blown there is just no power going to it so I was wondering if that is why I still have that 5e15 code?
Mini throwing codes Bernhardt97 First Generation Faults & Fixes 4 May 27th, 2018 08:20 AM
Thinking of throwing your old OEM MCS wiper blades out? pcmike Florida Region 9 Dec 19th, 2011 11:53 AM
Stone throwing good for nothing chavs. r34ver General Discussion 16 Apr 13th, 2005 02:53 PM
So who's throwing the New Year's bash? MetalMiniMayhem New York & New England Region 14 Dec 28th, 2004 03:17 AM
Throwing some gas on the JCW argument collinsc General Discussion 10 May 8th, 2003 01:56 AM
