Clutch pedal stuck in down position. Just renewed 2 calipers and bled the brakes not sure If this is related. Got plenty of fluid in the resivoir. Any ideas?
Bleed the brakes again. Be sure you follow the right order of which caliper to bleed first, 2nd, 3rd, and last. Also be very careful you do not let the fluid level in the reservoir get too low. If you introduce air into the system at the reservoir you will make getting the brakes properly bled even a harder task.
did you pressure bleed the system, if so could you have pressed the clutch pedal with pressure bleeder pressurised , I done that trick once and flipped the seals in master cylinder for clutch,
Clutch has a bleed screw on it too. Part of the system on my 03 S.
Related Threads
MINI Cooper Forum
posts
3.7M
members
176K
Since
2001
