Mini won't start. Yellow lift symbol and can't put it into ignition state.
13K views 6 replies 2 participants last post by  MiniOwner10
Thank you, I've looked them up and unfortunately they're over 200 miles way. However, I've contacted them and asked if there's anybody closer that they can recommend. Hopefully they will know someone down in Kent.
I watched the video, I believe what he is doing is also resetting the CAS/ELV, that unfortunately only works for me one time. As soon as I remove the key the problem comes back again.
there are some links in the description of the YouTube video to a device that emulates the Steering lock signal. That might be worth a try. It will mean that you steering doesn’t actually lock any more though.
Not sure how true that is...
My 17 plate bmw 225xe definitely has a steering lock on (can’t turn the wheel)
Our (share with the Mrs) 64 plate mini coupe r58 I’m 99% sure locks the wheel also.
the only issue would be if a thief got the car started then they wouldn’t need to worry about the steering lock.
