Replacing Dayco Friction Wheel - All You Need To Know
1 reading
3.5K views 6 replies 2 participants last post by  MickeyMini
#1 · (Edited)
Just replaced the Dayco friction wheel on my partners 2008 Cooper. Dayco have changed the plug and socket arrangement with the new unit, therefore you will need to buy a new plug housing (12527543313). The procedure for replacing the existing plug housing with the new one is straight forwards.
Before we get onto the topic of changing the plug housing, I have added a number of articles covering the associated wiring, calling system operation and replacing the friction wheel, see below. This should provide enough information to help repair/replace items and diagnose issues.
Back tot he plug housing, first, unclip the lead from the engine so that you can work on it from above. With the lead unclipped remove the ‘u’ shaped plastic sheaf which you will not use again. Next, with a small bladed screwdriver pry the plastic retaining tab that holds the orange and white wires in the existing plug. Note their orientation which is as follows: white wire is at the flat edge side of the existing plug housing, marked as No. 2 and the orange wire which is at the round edge side of the existing plug housing, marked as No. 1.
With the two wires removed from the existing plug, place them into the new plug housing in the same orientation. That is, white wire goes into the hole on the flat side and the orange wire goes into the hole on the round side of the new plug housing. Again, this is No.2 and No. 1 respectively. Push the flap down on the new plug housing to hold the connectors in place and that’s it. You can put some tape round the wires and plug to stop water ingress or use shrink wrap.
Image 1: Old plug housing, both wires in their correct orientation. - note flat edge.
Image 2: Old plug housing, while wire removed - note flat edge.
Image 3: Old plug housing, face of plug with flat edge.
Image 4: New plug housing, while wire on flat edge side of housing.
#2 ·
Hi, thank you very much!
Your documentation maybe solves more than one problem on my end…!
But for the friction wheel jockey connector I have additionally this question:
from your understanding, do the orange and white wires on the connector of the new friction wheel version vs the old version go to the same pins on the friction wheel jockey?
In other words, is white always beside the flat connector edge, both on old and new version of the jockey?
That would mean, one can use the old plug housing if he adds another notch to the car’s connector, so that it fits into the new outer plug housing, which has a different rib placement?
I added that notch some hours ago but in the end didn’t dare to plug it in
but then I don’t understand why they wanted to change the coding of the plug…
Here a pic for illustration:
Br, ICE
#3 ·
