Weirdo car
1 reading
75 views 5 replies 2 participants last post by  suityou01
#1 ·
Got an R56 1.6 Cooper with an N12B16A engine on a 56 plate with 149K miles. Been a good little runner these past few years. Now developed a weird problem. My recent test drive explains the problem exactly.
Got in and started her from cold. Warmed her up, cleared the calculated mpg value and headed out onto the road. Motorway, M1 Southbound JN10 to 6. Doubled back at 6 and headed back up to JN10. Car is driving beautifully. I'm not driving her hard, but also just cruising at 70m.p.h.
Head home and pull up on the drive. Calculated m.p.g. for this run is 44. Not bad for an old girl. Check the short term and long term fuel trim. Short term is oscillating between 0 and -0.78. Long term is -0.78. As far as I know these values are quite acceptable.
Then stop the car. Take the key out. Wait for 2 minutes. Key in. Start. Running like a tractor. Engine warning light for misfires on Cylinder 2 and 3. Turn off and on a few times. Same result. A warm start and she runs like a sack of manure with misfires.
Sparking plugs are not that old. Valve cover is new. Just changed the MAP sensor. Just fitted a new CAT. Timing chain only done about 20K. No discernible air leaks.
How does a car go from running that sweetly to running like a dog just by turning it off and on again?
I am stumped.
#2 ·
Took the weirdo car for the same run this morning. Rinse and repeat, exactly as happened above. This time I sprayed off the eccentric shaft sensor with a freeze spray to see if this would get the car to run right. Nope. Turned off. Sprayed again. Start. Nope.
Disconnect eccentric shaft sensor. Start. Running better. Not misfiring. Stop car. Reconnect eccentric shaft sensor. Start. Perfect, back to how it was when I returned from my run.
Weird.
#3 ·
I should also add that I have to change his Eccentric Shaft Sensor every 2-3 months. Could this all be pointing to a problem with the eccentric shaft motor? Perhaps it is sticky and drawing too much current thus wearing out the sensor, and causing this other weirdo fault?
#4 ·
when i try and diagnose a timing issue i disconnect the vvt motor plug so see if engine will run smooth when system shuts down the vanos system its a easy fast way to find a base point of running, any faults in vvt high lift will cover up a issue with vanos
