2012 countryman s wont start, replaced footwell speg
4.6K views 5 replies 2 participants last post by  mike1967
#1 ·
hello i have a 2012 mini cooper s countryman, water had gotton into the lowest pins in one plug on the speg module/fuse panel.
Car would turn over but not start tons of error codes, got a good used speg replaced (exact number replacement), all error codes gone but two
A87E ultrasonic sensor wire fault
C913 No message lin
Car almost started but didnt,(meaning it fired) turns over windows doors locks radio everything works fine but just wont start
Any ideas would certainly be apprecated
water ddint get any higher than stated , didnt get into anything but floor board on passenger side just to bottom of lowest plug and the lowest pin, replaced pin that was corroded in plug, and fuse panel speg whatever you call it
thanks again
mack
