My Mini is 2018, the story is like this:
- Suddenly one day I stepped on the brake and pressed the ignition button twice before starting the engine.
-The same thing happened on the 2nd day, it happened twice before it exploded.
-Then on the 3rd day, I stepped on the brake and pressed the starter button 3 times, the engine didn't start, then I stepped on the brake the 4th time and the car felt like it was locked, I couldn't apply the brakes deeply, the steering wheel was locked. Then the car said the battery was too weak. I took the battery meter and it was only 10V. Today I bought the battery and replaced it myself, then used the software to sync the new battery with the car and it said it was successful but the brake didn't work. I don't understand why the brake can't be pedaled deeply. When I changed the battery , I checked the brake fluid tank and saw that the brake fluid was completely dry, so I refilled the brake fluid. But it's been 2 days and now I can only pedal a little deeper, so I can't. enough to start the engine.
Do you guys know what's wrong with it? Is it possible that both the battery and the car brakes fail at the same time?? Is that a coincidence? Now my car has stopped showing battery error but the brake still can't be applied. What should I do? Please help me as soon as possible. I need a car to go to work.
