61 - 62 of 62 Posts
I just repaired the 2 broken latches with a $7 jb weld tube. The 2 front latches are a common fail point and are almost $300 new. Here is a photo of my jb weld repair and yes afterwards i cleaned and lubed the moving parts and the roof now works for the 1st time since i bought it a couple months ago!
Please! como has hecho para recolocar las plaquitas metálicas una vez que soltaste el plástico?
From my last post i still was having no success in using the roof in my mini, along with a string of issues it had when purchased a few months ago i was finaly able to get some of them resloved . This month was the rear supsension.
( bare with me it will all make sence )
The guy i got the car from said it looks to have been lowered from previous owner. I took it on faith, and searched up new sping,shocks, mounts and abs sensors as the abs light was on in the dash.
*side note: the speedo was also no working .
Okay jump forward to this weekend, got a friend i trust to swap out all of the above parts.
During the install, alarm bells rang ...........loud
The reat springs where snapped at the tails, meaning there where not on the shockbase plate but now being suppeneded but the abs sensor wire.!!!!!! View attachment 281224
Once i picked myself of the ground we set about replacing the shocks,springs,upper mounts and installed new abs sensors.
Both sides where the same, and after many hours in the sun shine she was all fitted up and lowered to the ground.
Now the test drive was a dream, speed rams where not killing my back or needing crawled over but just as important the speedo was now working.
With socially distance high 5`s all round, and a coffee latrer, i drove home.
Then remembered the central locking rest trick which i read here , hold central locking for 5 seconds and the windows went down. Gasp !
From i boughtthe car, i could open the sun roof but only on first key turn, not with reds or engine started and no roof retracting......................... But now it works , sun roof while driving , roof with engine running it alll works!!!
It turns out the Body control module tells the sun roof the speed of the car as a safety measure. If there is no speed information or cant reach the abs sensors , it defauls to NO movement to protect the roof mechanism.
I realise this was a long winded way of saying well that last 2 sentances, but i am hoping the more details put in these posts, the more help it can give someone.
Massive thanks to all the support i have got from here, it has been invaluable!!
Bring on the sunshine :cool:
I am having same problem with 2011 mini one, spring was snapped and stretching abs wire, when spring repaired and abs cleared the roof does not now fold back
61 - 62 of 62 Posts
