Rear lights not working
1.2K views 2 replies 2 participants last post by  simonhumphrey9
#1 ·
Hi all new here but need some help my rear lights do t work has anyone else had this problem break lights work fine so do all other lights had the footwell module sent away and tested as these seem to be the root of most problems with lights . I test all othere systems fuses had it on the computer and can see the module and see the switch Turning on and all light operation seem OK any help anyone can give me will be appreciated
#3 ·
Hi thanks did all of that but end up having to wire in a feed to some leds mounted in the rear lights feed from number plate lights, not the best solution but it works and doesn't show as a error on dash or code reader. I traced it all back to the frm model even sent it away to be repaired but they couldn't find anything wrong with it so had to do something
