aux water pump dead
3.7K views 5 replies 3 participants last post by  Cavids
#1 ·
so my mechanic says that the aux water pump is not working in my 2011 mini s. So until I replace it am I fine as long as I behave and not get in to the turbo much? As long as the engine is on does the normal cooling system take care of the turbo? Or is the aux the one that does it?
#2 ·
either way would not drive any car with any water pump diagnosed as being faulty all designed to work together and such a important part of any engine cooling
#3 ·
The VW VR6 2.8/2.9 engine, beautiful big old lump, in Golfs and Corrados has an electric water pump in addition to the normal mechanical one you'd expect. Tiny little thing. It 'runs on' after the engine has been switched off if it is needed. It fails and on many cars it is failed and probably has been for a while. Good if it is working but doesn't kill 'em if it isn't. Just isn't that good for them.
So what is the 'aux water pump' on a turbo R56? I know nothing about R56s, R53 myself.
