I recently purchased a 02 plate mini cooper... not long after i got it home the mrs started moaning about a clicking noise from the steering column when turning corners... Been a private sale not much we could do... so thought id leave it and see if it would go away...
The following day it drove me round the twist every corner click click click click!! it sounded like it was from the upper column... near the ignition barrel! so i looked around the forums and to my horror everyone was saying they had replaced the whole column and it was a common fault!! I decided i had nowt to loose and went for a look...
If you remove the 2 screws that hold the lower plastic of the column... then drop it down a few mm... remove the rubber off the egnition barrel (makes it easier to put back on.. release the steering adjuster and manouver the plastic off.. will be a little tight around the barrel but will slide off with no damage! under there you will see the steering mechinism... i have included a couple of pix sorry they aint brilliant but there off my fone!
At the back of it you will see a metal bar going thru a plastic fitting held in a metal casing... i have arrowed on picture... spray this with wd40 and it should stop the noise... if it does clean the wd40 off and apply some GOOD 3in1 oil... the wd40 generally dries out to quick so the 3in1 will keep it sweet for a while... no idea how long this will last but certainly gives u a nice QUIET enjoyable drive again! and the dreaded click is GONE!!
Would appreciate your feedback and let me know how you get on... may not fix all your minis but for the ten mins it takes worth a try as its certianly cheaper than bmws new column...!!!
:red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red: :red:
