The main difference as compared to the MINI xenon headlamps available ex works is the reduced light flux of 2,000 lumen. This makes it possible to install the headlamps without retrofitting the headlamp cleaning system and using manual range control. By contrast, the 35-watt xenon headlamps available as an optional extra can only be fitted with an automatic height control function due to legal specifications.
Globally unique: increased safety when driving at night with retrofit 25-watt xenon headlamp.
MINI is now the world's first automobile manufacturer to offer a retrofit xenon headlamp with an output of 25 watts and manual height adjustment. This gives owners of a MINI, MINI Clubman, MINI Convertible, MINI Coupé and MINI Roadster a low-cost option to add a highly effective and efficient light source to their automobile at a later stage. In terms of quality, luminosity and range, the retrofit headlamps are identical to the xenon light available for MINI as a special equipment feature ex works. They also offer a much longer service life and lower energy consumption than the standard halogen lamps.
https://www.press.bmwgroup.com/pres...tional-motor-show-iaa&outputChannelId=6&id=T0145218EN&left_menu_item=node__2318
